I have difficulties install autocad trueview 2013 on Windows 7 32bit Operating System.
The error message pop up is " this program might not installed correctly, try reinstall using settings that are compatible with this version of Windows. Refer attached error message.
The softcopy i installed is 'SetupDWGTrueView2013_32bit'. Please advise.
So if you select the second choice on that pop-up, does the program run?
Or did you stop when you saw the pop up?
