DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Problem install autocad trueview 2013 on Windows 7 32bit Operating System
3 REPLIES 3
1958 Views, 3 Replies
I have difficulties install autocad trueview 2013 on Windows 7 32bit Operating System.
The error message pop up is " this program might not installed correctly, try reinstall using settings that are compatible with this version of Windows. Refer attached error message.
The softcopy i installed is 'SetupDWGTrueView2013_32bit'. Please advise.
3 REPLIES 3
Please assist to feedback
pendean
So if you select the second choice on that pop-up, does the program run?
Or did you stop when you saw the pop up?
in reply to: pendean
Thanks for your help. Issues resolve after install autodesk instead of autocad trueview Thanks & Regards, Ling Soon Li Taikisha Engineering (M) Sdn. Bhd. (Kuching Branch) Lot 1201 Block 12, 1st Floor, Jala Setia Raja, Muara Tabuan, 93350 Kuching, Sarawak. +6012 568 8604
