DWG TrueView
DWG TrueView
Active Member
jcastiglioni
Message 1 of 8 (3,384 Views)
Problem editing AutoCAD object embedded in excel.
3384 Views, 7 Replies
06-05-2012 11:19 AM
Hello, I'm running AutoCAD 2008 and Excel 2010. I usually recive embedded dwg files in spreadsheets, and edit them by double click on them.
I didn't have problems until I installed DWG trueview 2010. Then these Ole objects, started being named as DWG TrueView Drawings (instead of Autocad Drawing as before), and can’t be edited double clicking them.
If you try to do this, a message box with the text "Cannot start the source application for this object" pops up.
I tried uninstalling Dwg TrueView 2010, and reinstalling autocad but it didn’t work.
I've also started with a new Excel sheet and new Acad drawing thinking there might be a version incompatability but I still get the same error.
If somebody had the same problem and found a work around, i will apreciate a lot the feedback.
I realize that this thread is a bit old, but I wanted to make sure and add a link to another thread where we've tackled this issue.
http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/Editing-Excel-2007-Embedded-Autocad-Drawing-Problem/m-p/3450194/highlight/true#M1493
Please post back here or private message me with any questions about the solution.
Active Member
cwt80
Message 2 of 8 (3,171 Views)
Re: Problem editing AutoCAD object embedded in excel.
09-27-2012 08:03 AM in reply to: jcastiglioni
I am having the same issue with AutoCAD 2008 and Excel 2010.
Any suggestions on how to fix this?
Active Member
jcastiglioni
Message 3 of 8 (3,164 Views)
09-27-2012 09:41 AM in reply to: jcastiglioni
Nope, I tryied almost everything without finding afix, or a workaround.
I Just edited the file with a machine with autocad 2010 and saved it to a *.dwg. No words from Autodesk since AutoCAD 2008 is not supported any more.
*Pro
ampster
Message 4 of 8 (3,155 Views)
09-27-2012 10:15 AM in reply to: jcastiglioni
no mention if you tried this,
try changing what opens .dwg files to "AutoCAD DWG Launcher" instead of plain acad.exe if that's what it is set to.
HTH
Active Member
cwt80
Message 5 of 8 (3,150 Views)
09-27-2012 11:20 AM in reply to: jcastiglioni
Did that work using AutoCAD 2010?
Active Member
jcastiglioni
Message 6 of 8 (3,126 Views)
10-01-2012 07:37 AM in reply to: ampster
List of "NOT working" tried solutions:
Setting  DWG Launcher o acad.exe as (*.dwg) file default opener.
Uninstalling DWG Trueview.
Change in excel the version of de OLE object.
Change something in the registry (there was a solution for the same problem with trueview 2006 an autocad 2004 or something like that, changing a registry entry, but it doesn't work for cad 2008 / tv 2010).
And a few more than i can't recall :smileytongue: sorry.
But, I didn't try reinstalling autocad, trueview and office all together, because it was much more trouble than install autocad 2010 in another machine and do the convertion there.
We still use autocad 2008 in all our machines because of compatibility issues with other softwars, and hardware limitations :smileyfrustrated:, so all who need to retrieve an embedded dwg on an excel file, goes to our AutoCAD 2010 machine.
Product Support
zalant
Message 7 of 8 (2,114 Views)
08-01-2013 08:29 AM in reply to: jcastiglioni
http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/Editing-Excel-2007-Embedded-Autocad-Drawi...
Zac Travis
Active Member
jcastiglioni
Message 8 of 8 (2,109 Views)
08-01-2013 11:43 AM in reply to: zalant
Thanks, that worked for autocad 2008 modifying the 2007-2009 .reg to point towards itself instead of to 2013. It didn't work for autocad 2000i although.
Juan Pablo.
