As someone who just discovered that this marvelous 'feature' is also turned on in a freaking drawing viewer, this needs unchecked by default in all future versions - including full-on AutoCAD and every non-Architectural vertical.
Hey Autodesk: NOT EVERY COMPANY TRYING TO USE YOUR PENDULOUS VIEWER IS A FIRM RUN ON BILLABLE HOURS, FFS.
In autoCAD Type 'plotstamp' at the command line. When the plotstamp properties window opens, click on the advanced button in the bottom left corner. Another window opens and towards the bottom is the option to uncheck 'create a log file' Then just ok your way out.
