I have tried to run the install three times- I run a 32bit Windows 7 and I have made very sure that I am installing the correct one, and yet- it still does not seem to want to install. Any ideas?
I would greatly appreciatte it, as this is getting more and more aggrivating.
Sam
Same thing here.
Fact 1:
I'm using a computer with a "Win XP 32" O.S.
I installed the "DWG TrueView" soft and I have been using it.
Fact 2:
I have tried to install the very same installer file to a computer with a "Win 7 32" O.S.
I have managed to install DirectX, but failed to install the "DWG TrueView" soft itself.
The log file contents follows:
2010/7/20:10:20:20 enjoy02 ENJOY2 === Setup started on ENJOY2 by enjoy02 ===
2010/7/20:10:20:31 enjoy02 ENJOY2 === Setup ended ===
2010/7/20:10:20:28 enjoy02 ENJOY2 === Setup started on ENJOY2 by enjoy02 ===
2010/7/20:10:21:49 enjoy02 ENJOY2 Install Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=2
2010/7/20:10:22:31 enjoy02 ENJOY2 Install Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=2
2010/7/20:10:22:43 enjoy02 ENJOY2 === Setup ended ===
Can someone please help me?
TIA,
Vini
"...Microsoft Visual C++ 2008 Redistributable (x64) Failed..."
err, why is it installing the 64bit version in your 32bit OS? It should be installing this one I believe:
Are you sure Win7 is 32bit? Did you deliberately purchase and install only the Win7 32bit? Very quirky indeed this Win7 business.
The download page does not offer any choice of download. It would appear that you'll always get the x86 version.
