DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
MS roaming profiles and folder re-direction
5 REPLIES 5
676 Views, 5 Replies
I have recently enabled roaming profiles and folder redirection (My Documents, Desktop and Application Data) for users of DWG TrueView 2008.
I don't know what effect this would have, if any, but it is possible that a user might roam to a computer that has AutoCAD 2008 LT installed as opposed to TrueView and then back to a computer with TrueView.
Should I expect to encounter any problems with this config in general?...with users roaming to computers with AutoCad and then back to TrueView?
5 REPLIES 5
Our initial success with roaming profiles for Autodesk Design Review was not
great. The issues got resolved in the 2008 release. I am not sure how much
experience we have with this for DWG TrueView 2008.
wrote in message news:5795228@discussion.autodesk.com...
TrueView?
I disabled roaming for all Autodesk applics, because Autocad takes almost 25Mb in profile, and our max profile size is 30Mb 🙂
How have you done this?
I don't use setup.exe but directly windows installer.
msiexec /i acad.msi ROAMING=0
ROAMING is case sensitive
That's all!
Thank you!
