DWG TrueView
New Member
sriilatham
Message 1 of 7 (882 Views)
missing shape font message
882 Views, 6 Replies
05-21-2013 03:59 AM
Actually I am using DWG TrueView 2014 and there is no such option available in this application which you have mentioned. Please suggest how can I get the missing shx file dialog box back.
Thank you
Edited by
Discussion_Admin
*Expert Elite*
rkmcswain
Message 2 of 7 (869 Views)
Re: missing shape font message
05-21-2013 05:17 AM in reply to: sriilatham
Log in as a different (new) user.
Does the message appear?
If so, then whatever is suppressing it is the HKCU portion of the Trueview registry settings:
HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R10\dwgviewr-xxxx:xxx\
Log back in as you, export this branch of the registry to a file (for a backup), then rename or delete it.
Launch TV.  If it doesn't work, then you'll probably need to reinstall anyway to restore this setting.
*Expert Elite*
rkmcswain
Message 3 of 7 (869 Views)
05-21-2013 05:19 AM in reply to: sriilatham
FYI: There is a forum for this application
http://forums.autodesk.com/t5/DWG-TrueView/bd-p/109
*Expert Elite*
Charles_Shade
Message 4 of 7 (858 Views)
05-21-2013 05:24 AM in reply to: rkmcswain
I was trying to get this moved detached and moved over to the TrueView Forum.
You beat Admin to it.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
*Expert Elite*
Charles_Shade
Message 5 of 7 (836 Views)
05-21-2013 07:51 AM in reply to: sriilatham
There is information on handling Fonts in the Help file for DWG TruView.
See if there is an answer or hint there for you. I do not believe the warning is part of this.
New Member
steven.xusz
Message 6 of 7 (723 Views)
07-05-2013 01:44 AM in reply to: rkmcswain
I have the same question, I am using DWG TrueView2011. When I open a .dwg file, 'Missing SHX Files' dialogue pops out. I checked the box 'Always perform my current choice', and clicked 'Ignore the missing SHX files...'. Then .dwg opened, but all text information were not displayed. I closed the .dwg, and reopen again, but this 'Missing SHX Files' does not pop out again.
I try to reinstall the DWG TV2011, but problem still here, I log in with other user, the 'Missing SHX Files' dialogue pops out again. When log back in mine, the problem can not solved, how and what shall I do?
New Member
steven.xusz
Message 7 of 7 (722 Views)
07-05-2013 01:46 AM in reply to: Charles_Shade
I try to reinstall the DWG TV2011, but problem still here, I log in with other user, the 'Missing SHX Files' dialogue pops out again. When log back in mine, the problem can not solved, how and what shall I do? .
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
