DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
missing shape font message
6 REPLIES 6
sriilatham
2226 Views, 6 Replies
Actually I am using DWG TrueView 2014 and there is no such option available in this application which you have mentioned. Please suggest how can I get the missing shx file dialog box back.
Thank you
Edited by
Discussion_Admin
6 REPLIES 6
rkmcswain
in reply to: sriilatham
Log in as a different (new) user.
Does the message appear?
If so, then whatever is suppressing it is the HKCU portion of the Trueview registry settings:
HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R10\dwgviewr-xxxx:xxx\
Log back in as you, export this branch of the registry to a file (for a backup), then rename or delete it.
Launch TV.  If it doesn't work, then you'll probably need to reinstall anyway to restore this setting.
rkmcswain
FYI: There is a forum for this application
http://forums.autodesk.com/t5/DWG-TrueView/bd-p/109
Charles_Shade
in reply to: rkmcswain
I was trying to get this moved detached and moved over to the TrueView Forum.
You beat Admin to it.
Charles_Shade
There is information on handling Fonts in the Help file for DWG TruView.
See if there is an answer or hint there for you. I do not believe the warning is part of this.
steven.xusz
I have the same question, I am using DWG TrueView2011. When I open a .dwg file, 'Missing SHX Files' dialogue pops out. I checked the box 'Always perform my current choice', and clicked 'Ignore the missing SHX files...'. Then .dwg opened, but all text information were not displayed. I closed the .dwg, and reopen again, but this 'Missing SHX Files' does not pop out again.
I try to reinstall the DWG TV2011, but problem still here, I log in with other user, the 'Missing SHX Files' dialogue pops out again. When log back in mine, the problem can not solved, how and what shall I do?
steven.xusz
in reply to: Charles_Shade
I try to reinstall the DWG TV2011, but problem still here, I log in with other user, the 'Missing SHX Files' dialogue pops out again. When log back in mine, the problem can not solved, how and what shall I do? .
