Actually I am using DWG TrueView 2014 and there is no such option available in this application which you have mentioned. Please suggest how can I get the missing shx file dialog box back.
Thank you
Edited by
Discussion_Admin
Log in as a different (new) user.
Does the message appear?
If so, then whatever is suppressing it is the HKCU portion of the Trueview registry settings:
HKEY_CURRENT_USER\Software\Autodesk\DWG TrueView\R10\dwgviewr-xxxx:xxx\
Log back in as you, export this branch of the registry to a file (for a backup), then rename or delete it.
Launch TV. If it doesn't work, then you'll probably need to reinstall anyway to restore this setting.
FYI: There is a forum for this application
http://forums.autodesk.com/t5/DWG-TrueView/bd-p/109
I was trying to get this moved detached and moved over to the TrueView Forum.
You beat Admin to it.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
There is information on handling Fonts in the Help file for DWG TruView.
See if there is an answer or hint there for you. I do not believe the warning is part of this.
