DWG TrueView
New Member
0 Kudos
Post 1 of 2
Measure Angle Precision
462 Views, 1 Replies
03-20-2014 08:21 AM
It appears the unit precision for measuring angles is rounding to the nearest degree.   Can the precision be set to 1 or more decimal points?
Member
0 Kudos
Post 2 of 2
Re: Measure Angle Precision
09-04-2014 02:12 AM in reply to: pndvorak
Not sure if you've already found this solution, but the setting is under the 'Format' drop-down menu.
Select 'Units' and then 'Units...'
Here you will see your angular precision is set to '0'. This can be changed to whatever precision you require, together with the actual angular unit you wish to use, direction of the angle calculation etc.
Hope this helps.
Post to the Community
New Post
