DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Make TrueView the default DWG application
4 REPLIES 4
966 Views, 4 Replies
Does anybody now what registry keys and values I need to manipulate to make dwg files always open with TrueView?
Any help regarding this will be greatly appreciated.
4 REPLIES 4
What is happening now? Each copy of AutoCAD "takes back" the DWG association
when you use it. Even if you set the registry value, the other AutoCADs will
stomp on it.
wrote in message news:6020977@discussion.autodesk.com...
So theres no way at all to make dwgs open in anything other than AutoCAD?
Autodesk DWG TrueView is a copy of AutoCAD. It should behave like AutoCAD.
If you open a DWG using DWG TrueView, it should be the default application
until you open a DWG with some other AutoCAD.
wrote in message news:6027723@discussion.autodesk.com...
That is unfortunately not the case when I have tried it.
Jimmy Bergmark - Owner/Developer
JTB World - Software development and consulting
Website: http://www.jtbworld.com
Blog: http://blog.jtbworld.com
SSMPropEditor - Edit properties on multiple sheets in a sheet set
http://www.jtbworld.com/SSMPropEditor.htm
AutoCAD 2009
http://www.jtbworld.com/autocad2009.htm
"Scott Sheppard - Autodesk" wrote in message
news:6027862@discussion.autodesk.com...
