DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Installati​on of on Citrix of Autdesk 2012 Design Review and DWG TrueView 2012
0 REPLIES 0
Message 1 of 1
1097 Views, 0 Replies
Dear All,
We are runing a Citrix environment consisting of Windows 2003 Servers and Presentation Server 4.5.
I have been trying to install and configure the following applications for my customers in house:
Autodesk Design Review 2012
DWG TrueView 2012
The installation of both applications goes very smoothly. Autodesk Design Review runs very well within the Citrix environment and initial testing has been positive.
DWG TrueView installs fine and I am able to run it initially as an administrator. Now when I run the application on a published Desktop or published application for my cutsomers I experience an issue. On intial launch the application attempts to perform an mini configuartion update. It downloads a large amount of data files into the users profile and updates user hive of the registry (no big problem here). Unfortunately it also appears to install information into the HKEY_CLASSES_ROOT of the registry hive which needs admin rights. The application exits immediately and I get an error to say user to not have sufficient access rights.
Has anyone managed to circumvent this problem or is there installation or configuration guide for Terminal Server available?
Thanks in advance
Mark.
0 REPLIES 0
