DWG TrueView
DWG TrueView
Active Member
0 Kudos
Post 1 of 3
Install error DWG TrueView 2013
2109 Views, 2 Replies
02-05-2013 06:06 AM
Hello, I receive error when install DWG TrueView 2013, can you consult? Thank you!
Log: https://gist.github.com/eyeland/3bc9d6960694cb476be9
*Pro
118 Kudos
Post 2 of 3
Re: Install error DWG TrueView 2013
02-05-2013 06:08 AM in reply to: eyeland
you'll need to search for and install .NET Framework 4.
370 Kudos
Post 3 of 3
02-05-2013 11:16 AM in reply to: ampster
http://www.microsoft.com/en-us/download/details.aspx?id=17718
And of needed: .NET Cleanup Utility:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
