DWG TrueView
DWG TrueView
New Member
micfarr
Message 1 of 5 (5,604 Views)
importing DWF/DWFx files into ACAD?? Please HELP !!!
5604 Views, 4 Replies
09-28-2010 09:32 AM
I don't have access to full blown ACAD, or Revit versions. Don't know what to tell client? Is the import of Acad Design Review DWF/DWFx files into Autocad or Revit even possible? How is it done?
Product Support
Shawn_Niles
Message 2 of 5 (5,595 Views)
Re: importing DWF/DWFx files into ACAD?? Please HELP !!!
09-29-2010 06:54 AM in reply to: micfarr
Yes, you can bring DWF files into AutoCAD as an underlay. You would use the XREF command to complete this task.
Shawn Niles
New Member
micfarr
Message 3 of 5 (5,575 Views)
10-01-2010 06:25 AM in reply to: micfarr
This has been done...problem now is that none of the information added through Autodesk Design Review is visible once I import through ACAD..Only the original base DWG that was brought in to ADR can be seen. Everything I marked up to the drawing is lost???
pendean
Message 4 of 5 (5,556 Views)
10-04-2010 05:15 AM in reply to: micfarr
Markup Set Manager is what needs to be used in AutoCAD:
http://docs.autodesk.com/ACD/2011/ENU/sitesearch.html?q=markup
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
FilipeAntunes
Message 5 of 5 (3,614 Views)
02-07-2013 08:05 AM in reply to: micfarr
I would like to import some markups produced for another user in a dwf file, but is impossible. I suggest that will be possible in future updates. Thanks.
