DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
How to set "Pan" as the default Navigation?
2 REPLIES 2
lwague2
2042 Views, 2 Replies
Does anyone know if it's possible to set the default navigation method to Pan? In other words, when a drawing is opened I'd like TrueView to default to Pan instead of the crosshairs cursor.
Thanks in advance,
L. Wag
Tags (1)
2 REPLIES 2
freeman_lincolnjr
in reply to: lwague2
Press Spacebar to switch to Pan mode.
pendean
@lwague2 Hold your mouse middle-button/wheel down then move it at the same time: that's a Windows feature too if you've never discovered that in other applications.
You can also scroll your wheel button to zoom in and out: where your crosshairs reside is where the center of the zoom in/out remains.
