Hi
I'm looking for an ActiveX or .Net component to be able to display a dwg file and get properties of any arbitrary object within it. (I don't need to edit the dwg file.)
I downloaded "DWG TrueView" software and then added an instance of "AxAcCtrl " ActiveX control to my C#.Net application form. It can display dwg files elegantly, but I couldn't select an object (e.g. Line, Circle, etc) to obtain it's properties.
Is there any way to do that with this ActiveX control? If not, is there any component to be able to do that?
Thanks in advance
Mehdi
