DWG TrueView
DWG TrueView
New Member
Jingqg1979
Message 1 of 8 (1,886 Views)
How can I get the 'missing SHX files' dialogue back?
1886 Views, 7 Replies
03-27-2012 04:12 PM
All,
 I am using DWG TrueView2011. When I open a .dwg file, 'Missing SHX Files' dialogue pops out. I checked the box 'Always perform my current choice', and clicked 'Ignore the missing SHX files...'. Then .dwg opened, but all text information were not displayed. I closed the .dwg, and reopen again, but this 'Missing SHX Files' does not pop out again.
How to get this 'Missing SHX Files' dialogue back? Please see the attachment.
Thank you!
Member
gdavila911
Message 2 of 8 (1,191 Views)
Re: How can I get the 'missing SHX files' dialogue back?
09-11-2013 08:28 AM in reply to: Jingqg1979
I have the same problem.
pendean
Message 3 of 8 (1,185 Views)
09-11-2013 08:35 AM in reply to: gdavila911
In AutoCAD it's the OPTIONS command's SYSTEM Tab, Hidden Messages Settings button.
Is there one in your DTV version?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
gdavila911
Message 4 of 8 (1,181 Views)
09-11-2013 09:57 AM in reply to: Jingqg1979
No, I dont have that option.
Member
gdavila911
Message 5 of 8 (1,169 Views)
09-11-2013 02:14 PM in reply to: Jingqg1979
  • I found a solution that worked for me.
Im using windows 7 PRO.
It looks like the settings are sotred in each user profile, so, the long and easy is to reload the user profile, or reimage the computer.
The short and easy is to delete the profile.aws file that is stored here:
DWG 2013
C:\Users\user_name\AppData\Roaming\Autodesk\DWG TrueView 2013\R10\enu\Support\Profiles\Unnamed Profile\profile.aws
DWG 2011
C:\Users\user_name\AppData\Roaming\Autodesk\DWG TrueView 2011\R8\enu\Support\Profiles\Unnamed Profile\profile.aws
If you have prevous versions installed, then probably you will need to delete the file in both folders.
If delete just the file doesnt work, delete all the contents of the Profiles folders for each version installed.
It would be nice if Autodesk includes a reset profile button in a future.
Please let me know if this works for you.
Thanks.
Charles_Shade
Message 6 of 8 (1,155 Views)
09-12-2013 07:05 PM in reply to: gdavila911
I did dig into the Registry a bit to see if there was a Key that could be changed to bring back the dialog but did not see any obvious candidates. Though this is likely where it is stored.
Maybe someone else here would know which to look for.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Member
gdavila911
Message 7 of 8 (1,152 Views)
09-12-2013 07:28 PM in reply to: Jingqg1979
I don't think is in the registry.
DId you checked my previous answer?
This worked for me:
Delete the profile.aws file that is stored here:
DWG 2013
or here
DWG 2011
Probably you will need to delete both if you have them.
rkmcswain
Message 8 of 8 (1,117 Views)
09-24-2013 08:13 AM in reply to: gdavila911
Thanks.
No it doesn't.
What did work was editing the file "%appdata%\Autodesk\DWG TrueView 2013\R10\enu\Support\Profiles\FixedProfile.aws" and removing this portion of the XML file:
/Profile/StorageRoot/AcApData/HideableDialogs/HideableDialog[6]/Acad.UnresolvedFontFiles
(your path may vary depending on what dialog you are trying to restore)
Use an XML editor, or if you don't have one, here is an online XML editor: http://xmlgrid.net/
