DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Forcing Trueview to load in 1024x600 Help!
3 REPLIES 3
691 Views, 3 Replies
Is there a way to force TrueView to use 1024x600?
I can only print right now from a computer with a max resolution of 1024X600. I know Trueview CAN work in this resolution because I have run it on another computer before, and switched the res down to 1024x600 while trueview was open to test and it functions fine. Right now I just need to force it to LOAD at that resolution. It may not be ideal, but it is all I have right now.
Please help.
3 REPLIES 3
pendean
Minimum system requirements are 1024x768, sorry 😞
in reply to: pendean
Well I know that is what it says, heh... but we know software is always haivng undocumented and dev. features/switches.
I figure there must be a switch or something (maybe a config file somewhere) that can be used to force it to ignore resolution detection when it is loading, OR to force it to load with an alternate resolution profile, such as 1024x768, but while in 1024x600.
It RUNS in 1024x600 just fine. It just won't LAUNCH in 1024x600. Unfortunately, I need it to launch in 1024x600 on the pc I am able to print from.
pendean
DTV is AutoCADbased, AutoCAD won't launch in less than 1024x768 and can be made to function in that lower res.
You may see if anyone around here has a registry edit like this you can do: http://beinginventive.typepad.com/being-inventive/2011/11/closing-application-option-dialog-on-small...
