DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Fatal Error when opening file with filename containing '%20'
0 REPLIES 0
Message 1 of 1
petsti
620 Views, 0 Replies
When viewing a DWG-file from our company Document Management System, DWG TrueView 2012 crashes with a Fatal Error (unhandled exception). This DMS is accessed by a web interface. When viewing a file, Internet Explorer downloads it to cache, but doesn't substitute '%20' in the filename with spaces.
You can reproduce this problem by renaming a file to "This%20is%20a%20crash%20test.dwg"
Two remarks:
- The problem does not occur with all filenames with '%20' in it
- It also doesn't occur when DWG TrueView is already opened
My questions are:
- Are other users facing this problem?
- Can anyone tell me in what situations DWG TrueView crashes when using '%20' in the filename?
- Is it addressed to Autodesk, and/or is it solved in next version?
Before I posted this problem I've searched the forums, but I couldn't find information about it. But there's always a chance that I didn't use the rights search terms.
0 REPLIES 0
