after using trueView successfully for several months, i now get the following error when i try to open a DWG file:
FATAL ERROR: FATAL ERROR: (0x7eff5fooo5) c:\program files\autodesk\dwg trueview 2014\ascimobj19.dbx
it started happening in an older version, i reinstalled that version, the same thing happened, then i installed the latest version... same story.
the files open on a colleague's machine.
has anyone seen this or know of a fix?
thank you,
p.k.
