DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Error whilst loading DWG TrueView and running for the first time
4 REPLIES 4
jpnewson
9641 Views, 4 Replies
I am having problems in running DWG TrueView 2013 for the first time
Namely I get the following erroe meassages whilst trying to access the drawing folder to load a drawing:
In the first dialoge box titled
DWG TrueView Error Aborting
the message
FATAL ERROR: Unhandled Access Violation Writing 0x0000 Exception at 0h
and then is a seperate dialoge box titled
Error Report - Required Value Missing
with the message
An Autodesk product failed to send the required value for UPITOKEN.
The error report sent to Autodesk may be incomplete.
I have looked at other threads and there does not seem to be a clear resolution to this issue
I am using Windows 7 Professional  6.1.7601 Service Pack 1 Build 7601
Using installation files from autodesk SetupDWGTrueView2013_64bit
Does anyone know what the issue is, please?
4 REPLIES 4
Charles_Shade
in reply to: jpnewson
Agreed about not having a clear resolution.
Most that I have read points to .NET or Login error concerning the User account
This is the closest I found to a solution:
http://forums.autodesk.com/t5/DWG-TrueView/DWG-TrueView-2013-crash-after-loading-DWG/td-p/3410095
I would suggest that you run System Restore prior to the installation of TrueView. Use this to clean up your system as it were.
Or download and install REVO UNINSTALLER (Free) and use its most aggressive setting on the TrueView installation.
Though I am not sure that this will help you find any leftover TrueView entries int he Registry it may be a worthwhile exercise:
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Be sure that you are logged in as an administrator to your OS and try the install again.
jpnewson
Thanks for this – for the benefit of others this is the start of a solution. I cleared the download folder and any exploded compressed files and folders, all cookies, browsing history, internet temp files and temp directories under C:\Windows\temp and %temp% in a run command line. Then I used the installation from USA site, Design Review which includes True View – and success finaly.
andrzej
I had the same error and re-instaling did not help. Finally I realized, that my laptop has two graphic adapters. I changed settings, forcing DWG TrueView to work with NVIDIA graphics instead of the default Intel HD3000. This solved the issue with the error.
ukdxb012
I recently came across this issue...
To get round it i applied the /nohardware switch to the DWG Trueview shortcut and applied the change.
Once i did this, i could successfully open DWG Trueview and open a DWG file without the program bombing out and reporting the UPITOKEN error.
Duncan
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
