DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
error on closing trueview ( win7 64bit )
2 REPLIES 2
bernd_bsl
1689 Views, 2 Replies
Hi all,
after going through numerous issues getting trueview installed, heidi driver error, getting the package created etc etc for my win7 test group, i am down to the last step. "why does the report an error box pop up everytime a DWG is closed"
the previous install of trueview has no problem ( 32bit XP pro ) has none of the errors and issues that i have seen with the 64bit win7 build.
i can't see anything funky in the XP install like "run as administrator" or the user being in a group with higher permissions on the local machine.
has anyone else come across this?
2 REPLIES 2
pendean
in reply to: bernd_bsl
Try testing in diagnostic more to try and pinpoint any conflict:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6453117&linkID=9240617
If there are no crashes while in this mode, your issue is a system related problem.
bernd_bsl
in reply to: pendean
the apps guy in our team was able to resolve the issue by changing dwgviewer.exe.config file.
Original file:
<configuration>
  <startup useLegacyV2RuntimeActivationPolicy="true">
    <supportedRuntime version="v4.0"/>
  </startup>
<!--All assemblies in AutoCAD are fully trusted so there's no point generating publisher evidence-->
   <runtime>
                <generatePublisherEvidence enabled="false"/>
   </runtime>
</configuration>
Modified file:
<configuration>
  <startup useLegacyV2RuntimeActivationPolicy="false">
  </startup>
   <runtime>
   </runtime>
</configuration>
