Ao abrir o instalador, logo que aparece a tela "Setup Initialization", já acusa "Autodesk Installer Error Report".
Já tentei de tudo... reinstalar o Framework 4... procurar em fórums este problema e nada.
Quando clico a em View Report Details, aparece a imagem em anexo.
.NET Framework can be an issue with AutoCAD installs.
There are two things to do:
.NET Cleanup Utility:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
or
REVO UNINSTALLER The free version on its most aggressive setting will get rid of all files.
Use this as the uninstall instead of Windows and remove the .NET then reinstall from a Microsoft website.
(I'm not sure if Trueview has its own .NET installer.)
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Restore the OS prior to the install of the Trueview and then remove the .NET 4 install and start from there perhaps?
Basically clean the OS of any remnants of the Trueview install to two or three days ago.
