Solved by scottmoyse. Go to Solution.
Try the Remote Desktop method for now while you wait:
http://www.droidforums.net/forum/droid-applications/4244-cad-viewer.html
+1
I just found out that my coworker's ipad got the autocad love.
I'll be holding out for android.
We have attempted to fill the gap in Android where it has otherwise been left out.
http://www.talon-designs.net/andcad.htm
There is a demo (as well as a full version) available on the Android market, which will give you an idea of wether or not the feature set is ideal (or close to ideal) for your needs. Just search for "AndCAD" and you will find it.
Currently it supports a proprietary format that we created, but does allow for DXF import and export. (DXF format is currently in beta, but is improving steadily).
It supports your basic drawing commands: lines, polygons, circles, polylines, etc. It also supports layers, snapping, ortho/iso drawing, minimal line types, image import, and a handful of other features. The next release will have support for direct input as well as dimensioning. Following that is support for block libraries, mirror, offset, etc etc.
Regarding DWG format. Since the DWG format is proprietary to Autodesk, we have been unable to implement the abilities. The cost of licensing the "Official" DWG format is way to high for us to be able to proceed, unless we can get support in that area. If I recall, its about 2500 to licence the libraries necessary to implement it, and a yearly 1500 maintenance fee to continue. Unfortunately, we cannot afford said costs as of yet. That being said - it doesnt mean that it is out of the question. Just not in the books currently.
Anyway - feel free to let me know if you have any questions.
you do now:
http://autodesk.blogs.com/between_the_lines/2011/04/autocad-ws-mobile-for-android-is-available.html
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Hi, is there going to be an Android viewer for inventor files? Like a publisher viewer?! Cheers
and is the Buzzsaw app going to be ported over?
we should probably start a new thread, 'Requesting information about Andoid Apps"
Scott Moyse
Dont forget AutoCAD WS is on the Android as well for free and that is a perfect mobile DWG viewer and markup.
Cheers,
Shaan
Shaan Hurley
Technologist
Between the Lines Blog
@ShaanHurley on Twitter
Yes, and I need to get out here in the NG more often. 🙂
Shaan Hurley
Technologist
*AHEM* Perfect?
Isn't AutoCAD WS cloud based? So, if you do not have access to the cloud, it does nothing but rain on your perfect app.
Is it just too hard for Autodesk to write a simple viewer app for Android, or do they simply not care to?
