DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
DWG Trueview x64 Install Error
1 REPLY 1
euphos
795 Views, 1 Reply
I'm getting the following error when I try to install the x64 version in Win7 Pro.
Install files got extracted from the download to C:\Autodesk, so it seems weird that the it looking for files in my user directory.  I looked there, and all the same files for the extraction in C:\Autodesk are in that directory as well.
Ron
Ronald M Schildt, PTOE, PE
Kenosha County DPW
Bristol, WI 53104
1 REPLY 1
jessica.t
in reply to: euphos
Hi Ronald and welcome to the Autodesk Community!
Check out this solution to see how your antivirus software could be stalling your download. Running your machine as the administrator and disabling UAC may also be helpful, as listed in this thread. Making adjustments to your registry has also resolved the error but please be careful when making changes.
Please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer. If not, please respond with further details. Thanks!
Jessica Thrasher
