Hi Can anybody help,
I use DWG trueview to view DWG files on my laptop when out of the office and used to be able to use it to export files to PDF but for some reason this feature is now not working.
Whats really driving me mad is that i have used this function before although it may have been on a previous version of trueview but I'm not sure.
Any suggestions?
Solved by pendean. Go to Solution.
Sorry to chime in here, and sorry for sounding mad.
Please, how *censored* can I simply plot a few CAD drawings to PDF pages without having to click through an impenetrable thicket of print settings dialogs encapsulated in even more layers of print settings dialogs -- which also never seem to be saved in order to be re-used for the next drawing?
Help
Thank you Dean, that worked!
Only one more question with respect to the export feature: is it possible to adjust the line widths that the exported PDF will receive, before export?
Okay so I now have this 3D-DWG file opened in DWG TrueView:
If I use "Big Green D icon -> EXPORT -> PDF", I get this terrible result:
If I use "Big Green D icon -> PRINT -> Plot (to PDF)", I get this (even more yukky, and totally unusable):
So is there any chance to simply have whatever is shown in the main DWG TrueView window converted to high-quality PDF, preferably vector based? (eDrawings viewer could do that already more than 10 years ago.)
Thanks for help
David
I can't send you the actual model for confidentiality reasons.
However I attach a publicly available model which behaves similarly.
I'd like to export the current view (only outlines, see screenshot below) to a 2D vector format, either to PDF or to SVG, for example.
How can I do that? If I plot this model to PDF, I get a wireframe drawing with hundreds of excess lines, where however I only wanted the outlines:
Thank you
David
I just was going to to say that I bit the bullet and got SketchUp Pro. For non-engineers (although amusingly I once was an engineer ), nothing beats SketchUp's total package, i.a. with it's simple high-quality 2D vector export of 3D CAD models
I like TrueView (2018 & previous versions) because it loads faster than the mechanical just to get a schematic printed in monochrome. I realize this is a long standing issue but this is what I found after significant frustration and even a few (dozen) expletives along the way.
I tried both the plot and export function to get a pdf (my default printer) and TrueView just seemed to stall, the plot/publish icon acted like it was working but it never produced anything so I opened AutoCAD Mechanical and printed from there with no issues (same print settings). After viewing this post I did notice that I always printed in the backround by default as older PCs were just not comparable to the multitasking abilities of today. All that said, I unchecked the "Plot in background" plot option and it now prints.
