Every time I run DWG TrueView--which is ONLY for the purpose of translating AutoCad 2014/2105 files back to 2010 format--it resets my system so that DWG TrueView becomes the default for opening all DWG files. It is a multi-step process to reset this so that AutoCad is the default program. Does anyone know how to prevent DWG TrueView from doing this? It is aggravating to the point where I will likely remove DWG TrueView from my computer and ask our clients to do the transalting.
Solved by ukdxb012. Go to Solution.
