DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
DWG TrueView resets to be the default for opening DWG files
2 REPLIES 2
jaldegarie
8306 Views, 2 Replies
Every time I run DWG TrueView--which is ONLY for the purpose of translating AutoCad 2014/2105 files back to 2010 format--it resets my system so that DWG TrueView becomes the default for opening all DWG files. It is a multi-step process to reset this so that AutoCad is the default program. Does anyone know how to prevent DWG TrueView from doing this? It is aggravating to the point where I will likely remove DWG TrueView from my computer and ask our clients to do the transalting.
2 REPLIES 2
rkmcswain
in reply to: jaldegarie
That is the way it works. DWG files get associated to the last EXE used to open them. I just shut all CAD apps down, open my desired one (in my case Civil 3D 2015) and that resets it back.
More details here:
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/DWG-File-association.html
R.K. McSwain     | CADpanacea | on twitter
ukdxb012
Try this, we had the same issue but wanted to force Trueview to open before a licensed product... http://designandmotion.net/autodesk/mfg-pages/inventor/autodesk-dwg-launcher-wigged-out-fix/
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
