DWG TrueView
New Member
chanceski
Message 1 of 14 (743 Views)
DWG Trueview plotting
743 Views, 13 Replies
10-04-2006 02:26 PM
How do I plot multicolored layers in all black? Vovloview used to have a single command that would change the view to all black lines/text/layers so when it was plotted it would be legible.
Chance Rewolinski
crewolin@gapac.com
*Scott Sheppard \(Autodesk\)
Message 2 of 14 (743 Views)
Re: DWG Trueview plotting
10-04-2006 08:14 PM in reply to: chanceski
DWG TrueView is not Volo View. It is more like AutoCAD.
http://dwf.blogs.com/beyond_the_paper/2006/10/dwg_trueview_pu.html
If you want ease of printing, our focus is to share DWF files so you can
avoid all of the AutoCAD-isms of DWG. Volo View tried to make DWG printing
easier than AutoCAD, but all people did was complain that the printouts were
not exactly the same. With Autodesk DWG TrueView, they are the same, because
DWG TrueView is a copy of AutoCAD.
wrote in message news:5350965@discussion.autodesk.com...
Chance Rewolinski
crewolin@gapac.com
New Member
chanceski
Message 3 of 14 (743 Views)
10-05-2006 05:07 PM in reply to: chanceski
Scott, your answer is not specific enough. I still have no clue how to change the appearance of my printout so all the lines are black, not colored. Is there a phone number I can call for technical assistance?
Thx.
Message 4 of 14 (743 Views)
10-05-2006 05:17 PM in reply to: chanceski
wrote in message news:5352534@discussion.autodesk.com...
Thx.
*R.K. McSwain
Message 5 of 14 (743 Views)
10-06-2006 04:49 AM in reply to: chanceski
chanceski said the following On 10/5/2006 7:07 PM:
Did you read the article at the URL that was posted?
R.K. McSwain
http://rkmcswain.blogspot.com
SteveChestnut
Message 6 of 14 (743 Views)
10-25-2006 11:41 AM in reply to: chanceski
Hello R.K.
There's an easier way. From the menubar select "Plot".
The plot dialog box is identcal to AutoCAD. At the upper right corner under Plot Style Table select "monochrome.ctb"
Hope this helps,
Steve
Member
Dennis101
Message 7 of 14 (743 Views)
11-09-2006 12:31 PM in reply to: chanceski
I agree with the easier way big time but I am having a problem even with that method: Some of our desktops are printing some of the drawing text in a light shade of gray. When I use my desktop on the same drawing and printer, it prints good. I haven't been able to figure out what is different between the desktops.
Dennis
SteveChestnut
Message 8 of 14 (743 Views)
11-10-2006 06:24 AM in reply to: chanceski
Hey Dennis,
Is the printer you're talking about B&W or Color. If Color, see if you can go to the queue properties and set it to print in B&W.
Good luck,
Steve
Member
Dennis101
Message 9 of 14 (743 Views)
11-10-2006 07:09 AM in reply to: chanceski
Hi Steve,
Our printer is black & white. Our Plot Style Table assigns all the colors to be black. The grayscale is set to off.
This is so weird; we have the same program, drawing, and printer. 3 desktops are printing with some text at a light gray and the 4th desktop is printing it in all solid black. I have tried other desktops with this same drawing and program on other printers and they are printing good.
Dennis
New Member
acidity
Message 10 of 14 (743 Views)
11-20-2006 08:14 PM in reply to: chanceski
I can confirm this is a big problem.
I have changed all the plot style settings to monochrome.stb
All colours are changed to print in black only with greyscale off.
I am printing to a HP monochrome laser so I have no colour options to change in the printers settings.
However it just prints all light colours in greyscale not in black. ie it is ignoring the colour table when printing.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
