DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
DWG Trueview plotting
13 REPLIES 13
Message 1 of 14
1935 Views, 13 Replies
How do I plot multicolored layers in all black? Vovloview used to have a single command that would change the view to all black lines/text/layers so when it was plotted it would be legible.
Chance Rewolinski
crewolin@gapac.com
13 REPLIES 13
Message 2 of 14
DWG TrueView is not Volo View. It is more like AutoCAD.
http://dwf.blogs.com/beyond_the_paper/2006/10/dwg_trueview_pu.html
If you want ease of printing, our focus is to share DWF files so you can
avoid all of the AutoCAD-isms of DWG. Volo View tried to make DWG printing
easier than AutoCAD, but all people did was complain that the printouts were
not exactly the same. With Autodesk DWG TrueView, they are the same, because
DWG TrueView is a copy of AutoCAD.
wrote in message news:5350965@discussion.autodesk.com...
Chance Rewolinski
crewolin@gapac.com
Message 3 of 14
Scott, your answer is not specific enough. I still have no clue how to change the appearance of my printout so all the lines are black, not colored. Is there a phone number I can call for technical assistance?
Thx.
Message 4 of 14
wrote in message news:5352534@discussion.autodesk.com...
Thx.
Message 5 of 14
chanceski said the following On 10/5/2006 7:07 PM:
Did you read the article at the URL that was posted?
R.K. McSwain
http://rkmcswain.blogspot.com
Message 6 of 14
Hello R.K.
There's an easier way. From the menubar select "Plot".
The plot dialog box is identcal to AutoCAD. At the upper right corner under Plot Style Table select "monochrome.ctb"
Hope this helps,
Steve
Message 7 of 14
I agree with the easier way big time but I am having a problem even with that method: Some of our desktops are printing some of the drawing text in a light shade of gray. When I use my desktop on the same drawing and printer, it prints good. I haven't been able to figure out what is different between the desktops.
Dennis
Message 8 of 14
Hey Dennis,
Is the printer you're talking about B&W or Color. If Color, see if you can go to the queue properties and set it to print in B&W.
Good luck,
Steve
Message 9 of 14
Hi Steve,
Our printer is black & white. Our Plot Style Table assigns all the colors to be black. The grayscale is set to off.
This is so weird; we have the same program, drawing, and printer. 3 desktops are printing with some text at a light gray and the 4th desktop is printing it in all solid black. I have tried other desktops with this same drawing and program on other printers and they are printing good.
Dennis
Message 10 of 14
I can confirm this is a big problem.
I have changed all the plot style settings to monochrome.stb
All colours are changed to print in black only with greyscale off.
I am printing to a HP monochrome laser so I have no colour options to change in the printers settings.
However it just prints all light colours in greyscale not in black. ie it is ignoring the colour table when printing.
Message 11 of 14
Nb: I am opening a DWG file in DWG Trueview 2.
I do not have the luxury of telling our drafters to change the several hundred drawings on this site to be monochrome printer friendly
Also nb: The following menu options are not available in Trueview 2 : Plot or Publish.
I believe this to be a bug in the program
Message 12 of 14
Please try Autodesk DWG TrueView 2007.
wrote in message news:5402398@discussion.autodesk.com...
or Publish.
Message 13 of 14
I am using DWG TrueView 2007. I don't think that TrueView is the culprit because I have other desktops that can print the same drawing correctly using TrueView. There is something strange about three desktops that don't print the drawing correctly.
Dennis
Message 14 of 14
Hi Dennis101,
did you find a fix for this, I have the exact same issue x 4 desktops 1 of them prints perfectly the other three have grey scale effect on the sizes.
I have gone over the Trueview settings and the local printer settings but cannot find any differences?
