DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
DWG TrueView Error after closing
4 REPLIES 4
DerKnecht
1428 Views, 4 Replies
Hello Everyone,
Many Users in out Company uses the DWG TrueView 2013 (most of them to convert).
But one Computer has recently issus after closing the Viewer.
The Error Messages are well knowen in this Forum:
1) Fatal Error: Unhandled Access Violation Reading 0x0
2) An Autodesk product failed to send the required value for UPITOKEN....
What i found out till now:
This Error ocures with every user (domain or local, even admins) on this particulare pc.
The Error does not ocure if you open and close DWG TrueView without opening a DWG File.
It doesnt matter if an DWG File is on the network share or on a local disc.
Reinstall or Repair does not help either.
I found a similar looking thread called "error on closing trueview ( win7 64bit )" but the solution does not work for us.
Maybe you guys have another idea for me 😃
BR
4 REPLIES 4
pendean
in reply to: DerKnecht
What else is unique about this one PC? re-cloning it to match all the others would be a quicker fix IMHO.
DerKnecht
in reply to: pendean
hmm.. thanks for the adwise, ill consinder that.
energymech
Hi all,
I share with you my solution.
  1.  I've uninstalled the Trueview.
  2.  I've downloaded from Autodesk Viewer Site.
  3.  Installed the downloaded one.
That's worked for me! Smiley Wink
Kurdum DWG TrueView 2014 Windows 8 (64 bit) işletim sistemi;
açarken bu hatayı veriyor napmam gerekiyor
LoadLibrary 126 hatasıyla başarısız oldu: belirtilen modül bulunamadı.
