DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
DWG trueview and command regen
5 REPLIES 5
mpicard78
7775 Views, 5 Replies
Hi
I'm a problem with DWG Trueview. I'm not found a methode to do a command REGEN. It's nescessary because the line it's not good. All line was plane.
Who can help me?
thanks
5 REPLIES 5
rkmcswain
in reply to: mpicard78
Try changing the Visual Style to something other than what it is now.
For example, change it from 2D Wireframe to Conceptual, and then change it back. That should force a REGEN.
R.K. McSwain     | CADpanacea | on twitter
BalajiHTI
in reply to: rkmcswain
I am using DWG TrueView 2013. When I try to change the Visual Style to something other than what it is now, it shows
Unknown command "HIDDEN".  Press F1 for help.
ukdxb012
Can you not simply switch between the model and layout tab to force a Regen?
Just noticed your post is from 2012... Suspect you might not see this.
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
ukdxb012
in reply to: BalajiHTI
Have you tried the same process in DWG trueview 2015?
Duncan Brannan
Twitter | LinkedIn
BalajiHTI
in reply to: ukdxb012
Hello Duncan,
I tried switching between Model and Layout tabs but some fine circles still rendered as Octogans..
