DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
DWG Trueview 2014 freezes when plotting from layout tab
2 REPLIES 2
muddyrunnergirl
606 Views, 2 Replies
Hi All -
I have DWG TrueView on 2 separate machines and they both behave this way:
When plotting from ModelSpace there are no issues at all (tried PDF and hardcopy to an Oce TDS600 with perfect and expected results)
However, when in a Layout Tab, if I go to print, the plot dialog doesn't even show up, just the little spinner that indicates the computer is "thinking".... and then I evenutaly just have to shut down TrueView because it never goes further than the spinner.....
Both computers are Windows 7, 64 bit
All of our standard plot support files have been setup for TrueView (Model Space plotting is a success)
Anyone hae any insight as to what could be the culprit?
Thanks so much!
 - MRG
2 REPLIES 2
oosterop
in reply to: muddyrunnergirl
So layout printing doesn't work on both machines? Otherwise it could be a hardware problem.
I think you should frst convert the drawing to former version, than restart True view and load the converted version.
Than it should work.
pendean
Layout tabs are probably defined with a plotter/printer you don't have or one the is no longer active, or the layouts have issues, which is another issue out if your control in the viewer ( you need AutoCAD).
