I have installed the application Autodesk DWG TrueView v2013 in Windows 7 64-bit platform. When I have checked the functionality of the application, one of the option which is not working. The path for the option is File -> Open File From Cloud. Could you please assist me on this.
Praveen T R
Solved by Charles_Shade. Go to Solution.
Agreed same here. Appears to be a dead choice in the dropdown menu.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
