I have a system that crashes when you try to plot a drawing from DWG Trueview 2013.
System info:
Windows 7, 64-bit
DWG Trueview 2013, 64-bit
Jacques
Solved by pendean. Go to Solution.
All printing tasks? Or just when you aim for an HP printer at 11x17 paper?
Plotting to what?
Interesting, it only crashes plotting to the HP using 11x17 paper. If I select letter on the HP, Adobe PDF, or use the Savin Printer/Copier it works fine.
Jacques
Win7 64bit and HP are the problem then, known issue since Win7 64bit debuted: you need to download and install HP's Universal Driver for Win7 64bit and use it exclusively.
