DWG TrueView
DWG TrueView
Member
gregor2005
Message 1 of 10 (9,508 Views)
DWG TrueView 2013 64bit, installation: asp.net 4 problem
9508 Views, 9 Replies
06-18-2012 12:16 PM
hi,
i have a problem during installing dwg trueview 2013 64bit on an windows 7 64bit professional. i get always the following error wheter i have installed it or not.
i downloaded the current available asp.net (dotNetFx40_Full_x86_x64) with all updates
error message: you must first install microsoft .net framework version 4.0 sp1 or greater berfore installing this product
i hope anybody could help.
greetings
gregor
It needs SP1 for .NET Framework 4.
This may help, it's what I use for mass deployment for my company.
Article IDs for .NET Framework 4
2656405
2656351(2 updates)
2604121 (3 updates)
2656405
2487367
982671 (Actual .NET 4)
2487367
Just go to Microsoft and download the KB articles mentioned above. Hope that helps.
Member
gregor2005
Message 2 of 10 (9,363 Views)
Re: DWG TrueView 2013 64bit, installation: asp.net 4 problem
06-26-2012 11:47 AM in reply to: gregor2005
push.
no ideas?
Member
edgonz
Message 3 of 10 (9,284 Views)
06-28-2012 07:14 AM in reply to: gregor2005
2656405
2656351(2 updates)
2604121 (3 updates)
2656405
2487367
2487367
New Member
FrancisNYC
Message 4 of 10 (8,942 Views)
07-11-2012 11:57 AM in reply to: gregor2005
Download net frame 4.5 from microsoft site. if still got problem email me i can teamview to install for u
Francis
mycomputer_2002@yahoo.com
Member
gregor2005
Message 5 of 10 (8,933 Views)
07-11-2012 04:07 PM in reply to: edgonz
@edgonz: thanks for your hints. after install all kb's and separate all out i found it was that i have to install asp.net 4.0 full and KB2604121. now its time to deploy it on all workstations :-)
king regards
gregor
New Member
FrancisNYC
Message 6 of 10 (8,714 Views)
07-19-2012 07:57 AM in reply to: gregor2005
Congrat! have problem feel free to drop email to me. Best regards ? Francis Ng
New Member
watassek
Message 7 of 10 (5,954 Views)
10-31-2012 10:33 PM in reply to: gregor2005
so I am still having this problem today, does Autodesk even care to address it?
*Pro
ampster
Message 8 of 10 (5,938 Views)
11-01-2012 06:38 AM in reply to: watassek
this forum isn't for contacting Autodesk about problems with their software.  The forum was created by Autodesk for end users to submit questions/answers, and every now and then an Autodesk employee might jump in and provide some help.
Other than that, have you tried the suggestions listed above, stated by the OP as to have been solved?
Valued Contributor
Barvas11
Message 9 of 10 (5,887 Views)
11-02-2012 08:20 AM in reply to: ampster
Agreed! There are posts regarding this issue all over the autodesk forum but they don't work! Some patch would be good. This looks like that Autodesk issued software without checking if it can actually be installed on different operating systems.
Distinguished Contributor
madcowscarnival
Message 10 of 10 (5,812 Views)
11-05-2012 06:48 AM in reply to: Barvas11
The solution I found was apparently in the installation package of the full version of ACad 2013.  As in, by installing the autocad package, the necessary modifications were made by the software to the .NET framework; when tried again True View could then be installed without the previous .NET error.  It was very frustrating, and still is since that makes for a long-way around to a fix.
