DWG TrueView
DWG TrueView
Member
ivankey
Message 1 of 4 (842 Views)
DWG TrueView 2013, 2014 error to make preview or to print
842 Views, 3 Replies
10-01-2013 04:07 AM
Then i try to send print task (or make preview) in DWG TrueView 2013, 2014,  i take  "FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at e2561fe6h"
It be, then a use real prtinters such as HP5200, HP3525 (they configurade by HP uneviersal driver), but one of my printers work correct it's HP 1300 (it dosnt use HP uneversal driver).  Then a use DVG to PDF - print task (or make preview) work good.
I use Windows 7 Professional SP1 32bit or 64bit
Would you help me?
*Expert Elite*
Charles_Shade
Message 2 of 4 (834 Views)
Re: DWG TrueView 2013, 2014 error to make preview or to print
10-01-2013 05:16 AM in reply to: ivankey
Welcome to the Autodesk Forums!
So you can get a print to one of the HP Printers (1300) and DWG to PDF will complete a print for you.
The other two printers will not work. You suspect the HP Universal Driver.
Are these two printers WIndows installed printers or are you trying to use a PC3 file when printing from DTV?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Member
ivankey
Message 3 of 4 (831 Views)
10-01-2013 05:20 AM in reply to: Charles_Shade
 These two printers WIndows installed printers.
*Expert Elite*
Charles_Shade
Message 4 of 4 (822 Views)
10-01-2013 05:29 AM in reply to: ivankey
Can you roll back the driver or change the driver to the one that works on the other printer?
The Print and Plot Forum can be found here:
http://forums.autodesk.com/t5/Printing-and-Plotting/bd-p/30
There might be something there that pertains to DTV; if so, please link it nack here.
Announcements
Need installation help?
