DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
DWG TrueView 2012 Desktop Shortcut and Path
0 REPLIES 0
Message 1 of 1
dziller
828 Views, 0 Replies
Hello everybody!
I come from Austria (near Germany) and I have a problem with the parameter for the setup.exe.
I use the command setup.exe /w /t /q Setup.ini and I edit the Setup.ini (both Setup.ini also in \x64\dwgviewr\Setup)
#==================== Install Info
INSTALL_PATH=%ProgramFiles%\TrueView
CREATE_DESKTOP_SHORTCUT=NO
 but allways it create a desktop shortcut and it installed in the folder C:\Program Files\Autodesk   why!?
I must use this function for Software deployment...
Thanks!
0 REPLIES 0
