DWG TrueView
DWG TrueView
New Member
dziller
Message 1 of 1 (468 Views)
DWG TrueView 2012 Desktop Shortcut and Path
468 Views, 0 Replies
08-23-2012 05:15 AM
Hello everybody!
I come from Austria (near Germany) and I have a problem with the parameter for the setup.exe.
I use the command setup.exe /w /t /q Setup.ini and I edit the Setup.ini (both Setup.ini also in \x64\dwgviewr\Setup)
#==================== Install Info
INSTALL_PATH=%ProgramFiles%\TrueView
CREATE_DESKTOP_SHORTCUT=NO
 but allways it create a desktop shortcut and it installed in the folder C:\Program Files\Autodesk   why!?
I must use this function for Software deployment...
Thanks!
