DWG TrueView
DWG TrueView
New Member
0 Kudos
Post 1 of 6
DWG Trueview 2012 and IE8
3410 Views, 5 Replies
06-10-2011 07:48 AM
I have Windows 7 64-bit and Internet Explorer v8. We are running IE 8 in compatibility mode. I have DWG Trueview 2012 x64 version installed. When I try to open a file from our intranet on the Windows 7 image Internet Explorer launches with a blank page. DWG Trueview app is open but the file does not launch in the application. I have checked file associations and .dwg files are associated with the DWG proram. How can I get my .dwg files to open in DWG Trueview 2012 instead of an IE page?
Distinguished Contributor
0 Kudos
Post 2 of 6
Re: DWG Trueview 2012 and IE8
08-31-2011 11:18 AM in reply to: nette500
Hi nette500 - We are also having the same problem with ie9.
Have you found out how to launch your .dwgs from an ie8 browser?
New Member
0 Kudos
Post 3 of 6
10-14-2011 12:52 PM in reply to: nette500
I loaded net Framework 4.5 for it to work. 4.0 gives error.
New Member
0 Kudos
Post 4 of 6
10-21-2011 01:21 PM in reply to: nette500
 I just want to state that the same thing occurs for our client. With DWG Trueview 2012 and IE8, you can't open them in a window anymore.
Any work on a fix?
New Member
0 Kudos
Post 5 of 6
12-14-2011 07:50 AM in reply to: nette500
So if I install the .net framework 4.5, would it work properly?
New Member
0 Kudos
Post 6 of 6
12-21-2011 07:37 AM in reply to: david.moran
regsvr32.exe /u "C:\Program Files (x86)\DWG TrueView 2012\acctrl.dll"
