- Mute
- Permalink
- Report
I have just installed Trueview 2011, to test if the program can be of use to us.
One thing I've noticed is that it does not display Field codes used in attributes properly.
In our drawing border on each layout we have a field code in the drawing number attribute. This field code takes the file name + layout name, using the following code:
%<\AcVar Filename \f "%fn2">%%<\AcDiesel $(getvar,ctab)>%
The filename gets displayed just fine, but the layout name doesn't.
For example, a drawing with filename '123456.dwg', and layout name '-01', should be displayed as '123456-01' in the Drawing number attribute, when opening the file in AutoCAD.
In Trueview however, it returns '123456 $(GETVAR,??).
This makes Trueview useless to us when it comes to printing these drawings.
A fix for this would be appreciated.
Thanks!
