DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
DWG True Convert Tool
29 REPLIES 29
Message 1 of 30
165634 Views, 29 Replies
I just downloaded True View and tried to open a file. There is a warning box that comes up saying "This DWG file cannot be opened because it was created with a more recent version of DWG True View. Download the DWG TrueConvert tool from Autodesk to translate to different versions of DWG files."
Am I missing something - I thought the DWG TrueConvert tool was part of the download. Please help.
29 REPLIES 29
Message 21 of 30
Charles_Shade
Welcome to the Autodesk Forums!
Glad you came here to find it:
http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&siteID=123112
Many look but few seem to see.
Message 22 of 30
in reply to: Charles_Shade
Download the Autodesk TrueView software.
Open the TrueView application.
In the upper left corner there is a menu button that says DWG Convert.  Click the button.
DWG TrueView will now open a menu window to convert your file according to default settings.  Make the selection for which version of AutoCAD to convert to.
Make any adjustments you need to make to the default settings.
Press the "add files" button and select the files you want to convert to the files menu,
Press convert.
Wait for the conversion to complete, and open the file.
Good luck.
Please don't reply to this message to contact me as I will not monitor it.
Message 23 of 30
Charles_Shade
Too bad you will never know.
Your explanation was both poignant and elegant.
Message 24 of 30
I want to download the DWG True Convert Tool
Message 25 of 30
pendean
Please read what is already posted:
http://forums.autodesk.com/t5/DWG-TrueView/DWG-True-Convert-Tool/m-p/4382193#M18687
There is no stand-alone tool anymore.
Message 26 of 30
like to download dwg true convert tool
Message 27 of 30
jeffrey.sin
Hi seefantr,
As mentioned in the post above, DWG TrueConvert software is now included in Autodesk DWG TrueView. This is no longer available as a stand-alone software.
Here is the link with with the instruction on how to get the tool:
Jeffrey Sin
Autodesk Customer Support
Message 28 of 30
pendean
TLDR? 🙂
Message 29 of 30
Message 30 of 30
