DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Drawing is not valid error
3 REPLIES 3
aevansgr
499 Views, 3 Replies
I got the "drawing is not valid" message while working in AutoCad 2004.
I was importing jpg files and tracing them, then deleting the jpg.
I would greatly appreciate help with it.
The file is 2.58 meg and over your limit.  Can I send it somewhere else?
Gregg
my e-mail is gregg.s.evans@jci.com
Gregg S. Evans
Tags (1)
3 REPLIES 3
pendean
in reply to: aevansgr
ZIP not an option on your PC?
or try the many free services on the internet like www.wikisend.com
aevansgr
in reply to: pendean
I didn't think the file would compress that small.
The zip file is attached.
Any help opening it would be greatly appreciated.
Gregg
Gregg S. Evans
pendean
Your file is dead and gone: AutoCAD 2011 and 2012 would not recover it, neither will two other non-autodesk apps that can open DWG files. Hopefully you have a backup from the day before or earlier to use, or an autosave file you can rename and reuse.
