While waiting for 2009 to come out, I was wondering if there was a way to disable the installation of the DWGVIEWRCtrl ActiveX dll in the setup.ini of the DWG True View installer or some other area. I have continually been doing research on the Integration with Internet Explorer problem, have only found this knowledgebase article.
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2881054&linkID=9240617
This is all well and good, but still does not solve the problem. Adobe does not have this issue with pdf's and their plugin works flawlessly. Perhaps a lesson can be learned from them. In the meantime, a way to modify the installation of TrueView would suffice for me. The only thing I want removed is the integration with Internet Explorer and that would be enough of a solution for me. If there is a way to prevent the control from ever loading, I would like to know.
TIA
