i was able to successfully deploy DWG TrueView 2012 32 BIT on Windows 7 32 BIT without any problems by GPO Deployment Methods.
Now i am trying to do the same with DWG TrueView 2012 64 BIT on Windows 7 64 BIT and it fails with several error messages.
All pre requirements are already fully assigned like DirectX, dotNet 4 etc.
I think there might be a Problem with the Package itself when deploying, the error messages are as follows:
I Hope you dont mind when the first message is in german language:
First Message
Fehler beim Generieren des Aktivierungskontextes für "C:\Program Files (x86)\DWG TrueView 2012\acctrl.dll". Die abhängige Assemblierung "Microsoft.VC90.ATL,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.21022.8"" konnte nicht gefunden werden. Verwenden Sie für eine detaillierte Diagnose das Programm "sxstrace.exe".
Second Message
Product: DWG TrueView 2012 -- Error 1904. Module C:\Program Files (x86)\DWG TrueView 2012\acctrl.dll failed to register. HRESULT -2147010895. Contact your support personnel.
I hope there is someone out who are in the same situation and is able to give me some hints.
Best regards
