DWG TrueView
Member
edgonz
Message 1 of 3 (3,318 Views)
Deploying DWG TrueView 2013
3318 Views, 2 Replies
06-28-2012 07:09 AM
Hello everyone,
I was wondering if anyone knew of a way to prevent destop shortcuts from being created while deploying DWG TrueView 2013.
I was finally able to deploy this application, using SCCM 2012, but I'd like to prevent the desktop shortcuts from being created.
Also, I was able to install this application using: setup.exe /w /t /l /q setup.ini     (Note: for SCCM 2012, make sure not to enclose this command in quotes; leave it as shown)
What is the proper setup.exe parameter to uninstall it?
Thanks!
Member
edgonz
Message 2 of 3 (3,252 Views)
Re: Deploying DWG TrueView 2013
07-05-2012 01:21 PM in reply to: edgonz
FYI,
#==================== Install Info
INSTALL_PATH=%ProgramFiles%\Autodesk
CREATE_DESKTOP_SHORTCUT=NO
The above statement was changed in the setup.ini and doesn't seem to work. The shortcut is still created on the desktop.
Member
edgonz
Message 3 of 3 (3,217 Views)
07-09-2012 05:16 AM in reply to: edgonz
Okay, since it seems that there isn't any viable solution for removing the desktop shortcut for TrueView 2013; I used a batch file installation.
I created a INSTALL.CMD batch file, the the following content in it:
REM Install DWG TrueView 2013
REM Delete desktop shortcut created by SETUP.EXE for all users
del /q c:\users\public\desktop\dwgtru~1.lnk
If a user is logged on while TrueView is deployed, the user will see the icon on the desktop, but as soon as setup.exe finishes, the second line in the batch file will execute and remove the icon.
