When an employee converts a drawing that was used in 2014 AutoCAD down to 2012 he seems to be running into the problem that doesn't allow him to move and/or copy a line/object within one same drawings. This seems to me that it did not fully convert the drawing. Also, he has to now use the EXPLODE command to change these things. This is causing him to waste more time that shoud be nesessary.
We are using Autodesk DWG Trueview 2014.
The DWG file is coming from AutoCAD 2014. From what i am understanding is that TrueView is not the conversion tool the employee needs to convert the drawing to 2012 with everything intact?
