Hi there,
I have just replaced an old drawings viewer program throughout our organisation with TrueView 2009 (we are limited as to what we can install by our global helpdesk).
Is there any way that our users can convert drawings from .DWG to .TIF using TrueView? The old application could do this and if TrueView can't then the users that need this functionality want the old program back.
Any help much appreciated.
Tim
Solved by pendean. Go to Solution.
What format TIFF do you need? That's important.
Then you can use the ADD PLOTTERS... button in OPTIONS in DTV to create a raster firl format plotter with output to the crrect TIFF format you need.
