DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Convert 2007 file to 2004
10 REPLIES 10
Message 1 of 11
cds840s
10350 Views, 10 Replies
I am trying to convert a 2007 file down to 2004 to use at work. I downloaded trueview and I get an error message that says, "The files listed below could not be saved due to a sharing violation or disk write problem."
What is this?
Thanks.
10 REPLIES 10
Message 2 of 11
in reply to: cds840s
where is the file located?
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Message 3 of 11
cds840s
On the hard drive.
Message 4 of 11
Seabest
> {quote:title=cds840s wrote:}{quote}
> On the hard drive.
it is my problem ,too. anyone can help me,please!
my error :
Conversion SummaryConversion File Format: AutoCAD 2007/LT 2007 Drawing Format
Conversion package type: Folder (set of files)
Conversion Location: C:\Users\Dolphin\Documents\
Converted DWG files: 0
Recovered DWG files: 0
Conversion errors: 1
Conversion Errors
Unconverted files:
C:\Users\Dolphin\Documents\que tham dau.dwg
Edited by: Seabest on Mar 30, 2010 9:42 PM Edited by: Seabest on Mar 30, 2010 9:43 PM
Message 5 of 11
Post the dwg file
Dean Saadallah
http://LTisACAD.blogspot.com
Message 6 of 11
designer_tigger
I tried to convert from 2010 to 2007.
I am receiving the same error.
The drawing is saved on my desktop.
Is there a fix?
Tonia
Message 7 of 11
cindy
Has anyone come up with a solution for this yet?
I use the 32-bit version of DWG TrueView on my computer and I can convert a file no problem.
I use the 64-bit version on a colleagues computer and get the error message that the file could not be saved due to a sharing violation or disk write problem.
Any help would be appreciated.
-Cindy
Message 8 of 11
Tompax
I don't know how but i managed to solve this problem (it occured to me too).
In the window "DWG Convert" double-click on "convert to 2007 (in-place)", or in your case the 2004 line. A new window opens. Change File Format in the dropdown list to DWG trueview 2007/ Autocad 2007 drawing format. Now try again to convert your file, it worked for me.
Tom
Message 9 of 11
korgy
in reply to: Tompax
Tompax's solution (above) didn't work for me, but it gave me the hint to figure a solution that DID work.
double-click on the "convert to [2004][2007][2010] (in place)"  ...just as Tompax says.
under "Conversion package type" you have a list of choices.  i chose "Zip" (rather than "in-place").  i also checked the
"check and fix errors" box on the right -- but i dont think that was it.
in any case, the new Zip file worked just fine.  file opens up now.
Message 10 of 11
ivneol
in reply to: korgy
zip worked for me to
Message 11 of 11
fparente4XJPH
I found the following solution,
go to conversion setup, modify and change the file folder to the same place where is the file to convert.
I hope that help you.
Regards.
