1. No. Volo View Express honors the DWG creator's intent. The background
color is whatever color was used when the DWG was created. Volo View Express
does not have code to flip white text to black, so if you made your
background white permanently, you wouldn't see text in drawings from people
who used white text on black backgrounds. You can change the background
color, but only after the drawing comes up as the author intended.
2. You are not the first to have problems with fonts. Volo View Express
ships with the same fonts that ship with AutoCAD 2000. You shouldn't have to
do anything to get it to work with TTF. We use it with TTF all the time. We
are mostly using NT 4. I happen to be using Windows 2000. Now if you have
some fonts that are custom, you'll want to use the Volo View Express options
to specify the fonts directory where they are located. Some people have done
this, but still had trouble.
3. There is no zoom previous. WHIP! didn't have one, so we never considered
it for Volo View Express. You are not the first to ask for this.
4. WHIP! was an ActiveX Control and a Netscape Navigator Plug-in. As such,
there was no way to have a local help file. It was all done with HTML on the
site. Volo View Express is essentially the same thing, but it comes with an
EXE that acts like a shell that talks to the control. SO although there is a
place to do a proper Windows help subsystem, we never did that. The
assumption was that connectivity was getting ubiquitous and bandwidth is
expanding. Having the documentation on the site makes it easy to keep
current and accurate.
"Robert Shiffman" wrote in message
news:4650CFD24022FC83178269FBF80B6F75@in.WebX.SaUCah8kaAW...
> I just downloaded VV Express and have a few questions:
> 1. Any way to permanently set the background color (to white)?
> 2. Program refuses to read fonts from my AutoCAD fonts directory;
> also will not display truetype fonts.
> 3. Am I overlooking the "zoom previous" button?
> 4. It takes me about 4 minutes to connect to the internet. Is there a
> normal Help file out there somewhere?
